Jun 23, 2022 9:08 AM UTC
please fix it urgently
I am using Creo Parametric Release 9.0 and Datecode9.0.0.0
When the creo user open main assembly model showing this message and closed creo
ven I attached parts in main assembly suddenly its closed
Here are the errors that I faced
Fatal error encountered.A trackback had been written to C:\Users\Public\Documents\traceback.log please send it to
Technical Support
    hadardorAnswer
    Jun 29, 2022 11:51 AM UTC
    The used Hardware/Pltaform is not supported.
    StephenW
    Jun 23, 2022 10:29 AM UTC
    You can open a tech support case at https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
    Jun 23, 2022 1:38 PM UTC
    Indeed when you need the traceback.log file be analyzed, please file a case following the url shared by @StephenW
    Jun 23, 2022 4:13 PM UTC
    You do not need to create 3 requests for help for the same topic. It will be seen by the community and in this case refere you to PTC Tech Support.
    TomU
    Jun 23, 2022 7:18 PM UTC
    Keep in mind that the case logger itself is redirecting people back to the community and taking the information they enter into the case logger and using it to automatically create a community post.  A user has to explicitly say 'no' during the process to actually end up creating a case.
    Jun 23, 2022 8:59 PM UTC
    The 'No' response to actually create a Tech Support case needs to highlighted or defined better on the case logger page after Dylan returns its useless answers.
    hadardor17-PeridotAnswer
