Please help to cross check drawing name to be the same as instance name of part with family table
Let's say I have this generic_part.prt with three different instance:
1. generic_part1-a
2. generic_part2-a
3. generic_part3-a
"-a" suffix indicates revision name.
Then I create drawing which have the same name with each instance. for example "generic_part1-a.drw" for the instance "generic_part1-a.prt".
Sometimes, I did a mistake when using an instance in a different drawing name.
All I want is a counter to cross check whether the drawing name has the same name with the instance or not. I have tried any methods, but no success.
Can you show me how to solve this problem? Any help will greatly appreciated. Thank you.
I think ModelCHECK can do this.
Setting up ModelCHECK is a larger topic, though, and not easy to do if you haven't done it before. But ModelCHECK is the tool you're looking for.
