7-Bedrock
Please let us know how to replace Line stock through pro program.
I am using Creo Parametric - Release 2.0 (connected) Release 2.0 and DatecodeM250
    Hello @panand-2
    I'm not sure to have a good understanding of your business need with this question formulated a bit quikly. What I think to understand is that you would like to drive - via Pro/PROGRAM - the  presence of a given component (the line stock) in a given assembly, based on a given condition - for instance, the value of a string parameter.
    If you confirm this understanding, this can be done with good relations and correlated Pro/PROGRAM definition, according to the steps described in little movie attached (registered with sound for a better explanation).
    Hope this helps,
    Serge
