Dale_Rosema
Porting Creo Options over to Creo+
Is there a way to port over Creo Options over to Creo+ Options for all the setting?
Dale,
Try the PTC_CREO_ALT_SETTINGS_PATH in your Creo+ config.pro to point to your onsite Creo config.pro file (or a copy).
Article - CS384810 - Is it possible to read / load Creo Parametric configuration files (*.pro, *.sup & *.ui) from a location other than <creo_loadpoint>Common Files ext directory ? (ptc.com)
Dale_Rosema
What if they are two physically different systems?
Copy the onsite config.pro/config.sup to your Creo+ computer in any folder, then use the setting for the alternate locations.
