Possible to gather multiple point data in a csv file in WF5?
  • April 27, 2014
  • 0 replies
  • 568 views
I am attempting to generate the x-y coordinate data around a close curve (one curve generated from a family tree). In WF 5, I can march through Analysis, Geometry, Point which gives me the x y point data, which I can then copy over to notepad, but I want to be able to pick out 100 points for 20 curves so I'd like to not have to do this by cutting, copying, and pasting every single separate analysis.
Does anyone know if it's possible to collect multiple points in a single file ( either csv or .txt, which I could then write a script to remove all lines which are not pertinent)? Any guidance would be greatly appreciated. Thanks.
