Posting Bugs
Hi!
I found a thread from 2013 on how to post a bug, but it seems that thread is no longer valid.  Technical Support is no longer available as an option.
I want to report some bugs about Creo Manufacturing so that the Devs can work on solutions.
Thanks!
18-Opal
April 7, 2016
Hi Scott,
Could you add the link for the thread you mentioned?
Also, if you have a SCN (Service Contract Number), you can open case with TS from the Case Logger.  Then the TS engineer can check if the issue is actually a bug and file a SPR (Software Performance Report) for R&D to evaluate.
Amit
18-Opal
April 7, 2016
Hi Scott,
Amit
That's all I needed.
The thread is here
Thank you Amit!
