11-Garnet
Pressure vessel nozzle reinforcing pad model
Dear,
How to prepare the nozzle reinforcing pad in creo (refer the attached sketch)
dimensions
Shell OD - 3000mm x 12 thk
nozzle od -  1067 mm x 12 thk
R.F pad OD - 2000 x 12 thk
please provide the step procedure
Robert
tbraxton
tbraxtonAnswer
Assuming you have access to Creo 7 or newer and you intend to run FEA on the weldment.
Build the three components in part mode as separate bodies. The geometry is straightforward for each.
Multibody tutorials:
Creo 7.0/8.0+ Multibody Home: Start Here! - PTC Community
tbraxton
tbraxton22-Sapphire IIAnswer
ranto11-GarnetAuthor
11-Garnet
Is there any possibility to model as a single part ptc creo 9.0
I am looking for FEA study in Ansys
Robert
tbraxton
You can model this as a single part in Creo. The suggestion of using multibody will enable definition of bond elements between the welded components. The use of 3 bodies in a single part model is what I proposed above. You can also of course create multiple parts and add them to an assembly.
