Nov 16, 2011 12:50 PM UTC
Printing in Creo View
I have a customer that is trying to print a 2D model in CreoView. When he prints is prints in blobs of model. We have tried multiple printers for this user and still it is printing the same. We have tried changing the driver, printing to PDF and they all turn out the same. I have attached a picture of the model we are trying to print and the output that comes out of the printer. Has anyone experienced this before?Original.jpgPrinting from CreoView.JPG
Nov 17, 2011 8:43 AM UTC
Hello!
Are you using Creo View Express or Creo View Lite (and which service release)?
Nov 17, 2011 2:45 PM UTC
Express 1.0
Nov 17, 2011 4:23 PM UTC
Could you attach a example?
Nov 21, 2011 12:53 PM UTC
I am having the EXACT same issue as well... And one other user in my office as well. I emailed PTC support, and have crossed my fingers.
If someone found a resolution, please share.
Jan 3, 2012 3:11 PM UTC
What type of video card is on the machine you are having issue with?
Jan 3, 2012 3:58 PM UTC
There are multiple PC’s here with this same issue, so I assume we all have the same or similar video cards…
My PC says it’s an “Intel Q965/Q963 Express Chipset Family”, It’s part of a Dell OptiPlex 745.
This is a really bad bug... it's basically ruined Creo for our entire Engineering department, Many are wanting to go back to another tool, but Creo would be much better if it could print.
Thanks for any help you can offer.
May 22, 2013 1:52 PM UTC
We have had this problem since installing Creo View. We have tried updating drivers, bios, clearing cache, etc... No Success. We are only noticing it on older PCs using XP. Windows 7 seems to be working good.
We have help desk calls into PTC as well. This could have been a great thing for us as we upgraded to Windchill 10.1
If anyone has any success and can eliminate printing the checker boards, please share your success story.
Jun 4, 2013 7:16 PM UTC
Christopher,
This problem is caused by a bug in the Intel graphics drivers - the CreoView print engine makes use of the graphics chip. If the computer is running Windows XP you can disable graphics hardware acceleration -- which oddly enough doesn't seem to degrade graphics performance, at least not that I've seen. We usually see this problem on Dell computers with Intel graphics.
Try setting the environment variable PV_OFF_SCREEN_SIZE_LIMIT on the client computer to a value of 2048. You will need to close and re-open Creo View after setting this variable, but it should solve your problem.
Brian Geary
http://windchill101.com
Jun 13, 2013 3:23 PM UTC
I tried changing the PV_OFF_SIZE_LIMIT and it did not work.
Jun 21, 2013 1:13 PM UTC
Please double check your variable name, the one you typed above doesn't match the recommended name. Setting PV_OFF_SCREEN_SIZE_LIMIT = 2048 has fixed this problem on all of our machines with Intel graphics. This works on both Windows XP and Windows 7.
Brian Geary
Jan 22, 2014 5:18 PM UTC
We also have had these goofy issues with printing,, Shown above, or blank screen... This started happening when we switched from raster to PDF publishing.
I appears to me that the publisher was set for 300 dpi, and anything above that looks like this as far as viewers go. I finally figured out to change the local PDF viewer/printer to 300 dpi, and this resolved this issue for all users.
Jan 23, 2014 3:21 PM UTC
I tried to change the dpi to 300 and lower. Still no success.
Jan 23, 2014 3:59 PM UTC
Do you have Adobe, or Nuance or PDF set up as a system Printer.. i.e. Set up as a printer? That needs to be set up with the dpi at 300. See below image.
If so, run a test by Printing to it with a preview and see if that works.
Just changing a viewer will not do it, from what I have seen.
18-Opal
Oct 21, 2015 7:06 PM UTC
Hi Christopher,
If one of the responses helped resolve your issue, would you please mark it as the Correct Answer?  That way other users visiting the discussion will know; as the correct answer gets copied right below the question.
Amit
