Pro/E and OrCAD
Is there any who is using the IDF interface between Pro/E and OrCAD. We are using IDF back and forth between Pro/E and PADS and need info on the same interaction with OrCAD.
Questions:
Where do you document your fabrication and assy drawings?
Do you use the ECAD features in Pro/E to help the ECAD guy know where he can put the components?
How do you get the hole symbols into Pro for the board fabrication drawing?
How do you get the ref designators into Pro for the board assembly drawing?
John M. Scranton
Senior Designer
Ultra USSI
4578 E. Park 30 Dr.
Columbia City, IN 46725-8869
*Voice: 260.248.3576
*Fax; 260.248.3509
[cid:image001.jpg@01CAABDD.B5BB3EF0]
">http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="<a" style="COLOR:" blue;=" text-decoration:=" underline"=" target="_BLANK" href="http://www.w3.org/1999/xhtml">">http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html;" charset="utf-8"/>
<title>Untitled Document</title>
</head>
==-==-==-Internet Email Confidentiality Footer-==-==-==
Privileged, Proprietary, or Private information may be contained in this message. If you are not the intended addressee or responsible for the delivery of this message to the intended addressee, you are not authorized to possess or copy this message or its contents without the authorized consent of an UnderSea Sensor Systems, Inc. (USSI) representative. In such a case, you should destroy this message and notify us immediately. Opinions, statements, and other information expressed in this message are not published or endorsed by USSI unless otherwise indicated by an authorized representative independent of this message.
</html>
