Jan 19, 2024 8:57 PM UTC
pro e WF5 keyboard not available/disable
I am using Pro E WF5 and the keyboard is not working.
Is there a shortcut that enable and disable keyboard in pro E?
Apr 9, 2024 5:38 AM UTC
OK guys... I have a work around.
(1) Go to Setting -> Time & Language -> Languages & Regions
(2) Click [Add Language] and select (Chinese, Simplified China) -- It doesn't matter if you don't understand Chinese.
(3) You should now have a language selection option on your Windows Toolbar ENG
(4) Click on ENG. Select 拼 Chinese (Simplied China) instead of ENG English (United States).
(5) Now your Tool bar should have 中  拼 on it... click on 中 and it'll turn into 英 -- you'll see 英 拼 on your tool bar
(6) You are now in the English Input Mode of the Chinese input method. Everything you type will be in English just like normal.
(7) ProE/Creo WF5  will now work. You can enter file names and change dimensions.
(8) You can freely switch back to ENG English (United States) when you are not using ProE/Creo WF5.
(9) I know this is annoying. But until somebody fixes it in Windows this will get your projects done!
Trust me -- I tried undoing every windows update and every compatibility setting. Nothing else works.
Jan 21, 2024 8:10 PM UTC
Take a look some solution here - "Selection By Keyboard not available anymore in drawing mode since Pro/Engineer Wildfire 5": https://www.ptc.com/en/support/article/CS185600
Jan 31, 2024 9:32 AM UTC
Hello, MC_2211490 I also have the same problem with Creo1 M050, the keyboard doesn't work apart from "enter" and "backspace".
I occasionally use Creo1 to create normalizes for use with later versions of Creo.
Behavior that I also directly detected with the Creo1 installation setup.
On a virtual machine the keyboard behavior on setup is ok.
It more or less stopped working around the middle of January.
Apr 9, 2024 5:40 AM UTC
See above
Feb 14, 2024 5:52 PM UTC
My keyboard on my laptop has stopped working in Pro-E as well except for the del and enter key.  Nothing has been changed on the laptop either.  Worked fine before.
Apr 9, 2024 5:39 AM UTC
See my reply above
3-Newcomer
Mar 15, 2024 1:02 AM UTC
I'm having the same problem in ProE WF5.0 M070. It worked fine on a Windows 11 workstation until a few days ago, now only backspace and delete work. I can't enter any numbers or text in New Name field in Save a Copy, or dimension numbers in sketcher or extrude for example. The program is useless without. Tried the suggestion below but not related.
See my reply above.
3-Newcomer
Apr 9, 2024 12:35 PM UTC
Amazing, thanks much for the research and posting this solution. Annoying - yes, but it works!
