Pro/INTRALINK : Family Table Refers to Older Versions of Objects
Howdy!
I am having issue with Family Table.  The latest version (2.5) of the main file 123-456-XX.asm refers to non-latest version of the instances (ex: -01, -02, -03).  Is there a way to update the main assembly so that it refers to the latest version of all instances?
I hope that make sense.  We switched over to a different CAD software MANY years ago and I am VERY rusty with Pro/INTRALINK.  Also, because we are using Pro/INTRALINK 10.0 M030, it is no longer supported by PTC.
Any help would be greatly appreciated!  Thank you!
To clarify, the latest Assembly Generic (-XX) (version 2.5) contains non-latest versions of Assembly instances (-01 / -02 / -03 / etc.).
The previous version of the Generic (version 2.4) contains almost all of the latest Instances except for one.
I have tried following:
https://www.ptc.com/en/support/article/CS314555
but that article assumes that the non-latest Generic contains all latest Instances. (Not the case here).
and this:
https://www.ptc.com/en/support/article/CS128366
At this point, I am almost ready to delete latest Generic and that one Instance associated with latest Generic.
