Pro/PROGRAM - reading input values from file
Hello to all,
I have a part containing simple program (I am using Pro/PROGRAM functionality). I want to read input values from file. Unfortunatelly I cannot find the description of format for such input file. PTC Help and PTC Knowledge Base didn't help... Do you have some tip or link to PTC source ?
I use Creo Parametric 2.0 M020.
Martin Hanak
7-Bedrock
Hey Martin
Try this :
I assume you have the Pro/Program part ..... but I'll add it in case anyone else misses this step
In Pro/Program:
INPUT
DESIGNER STRING
ANY_NUMBER NUMBER
END INPUT
DESIGNER is a parameter of STRING type
ANY_NUMBER is a parameter of REAL NUMBER type
In the text file:
DESIGNER = "you"
NUMBER = 22.9
When you regen you get the pop-up that wants to know where the values inside the INPUT statement are coming from.
Select Read File and input the name of the text file
Voila!
Would it help to output a few files and see how they are formatted? Maybe a point file and a relations file?
7-Bedrock
Hey Martin
Try this :
In Pro/Program:
INPUT
DESIGNER STRING
ANY_NUMBER NUMBER
END INPUT
In the text file:
DESIGNER = "you"
NUMBER = 22.9
Voila!
Hello Jody,
thank you for your answer. Your solution works well in Creo Parametric 2.0 M020+. I wish PTC will add this information into their Help Center...
A little correction for other users:
Text file contents:
DESIGNER = "you"
ANY_NUMBER = 22.9
Best regards
Martin Hanak
