Problem with creating/modifying parameter with VBA
  • November 5, 2016
  • 0 replies
  • 992 views
I'm working on an Excel sheet that creates or updates parameters in all of the models in an assembly, but have a couple of issues.
1). How do I get, create, or change a parameter that belongs to an instance of a family table?
2). I can read and write some assembly parameters, but not all of them...even though I'm using the same code. For example, I can read an create/update a text parameter called "UPDATED", but not one called "PART_NUMBER"...even though they are both strings and both use the same code. The only thing I can think of is that the assembly in question belongs to an interchange assembly, but that doesn't explain why some parameters can be writeen and some can't.
EDIT: Also, I can't edit delete or modify the paramter in Creo either, even though it isn't used in a relation and is unlocked.
Here are some code snippets of what I'm doing:
' Get parameters
            For i = 1 To (params.Count - 1)
               Set param = params(i)
               Set ParamValue = param.Value
               Set ParamName = param
               If ParamName.Name = "PART_NUMBER" Then .Cells(iRow, colOriginalPartNumber).Value = ParamValue.StringValue
            Next i
            ' get material
            If mdl.Type = EpfcModelType.EpfcMDL_PART Then
               On Error Resume Next
               Set part = mdl
               Set material = part.CurrentMaterial
               .Cells(iRow, colOriginalMaterial).Value = material.Name
' Update paramaters
         ' PART_NUMBER
         NewPartNumber = .Cells(iRow, colNewPartNumber).Value
         If chkUpdatePN And NewPartNumber <> "" Then
            ParamName = "PART_NUMBER"
            Set oModelItem = New CMpfcModelItem
            Set oParamValue = oModelItem.CreateStringParamValue(NewPartNumber)
            ' Try to create the parameter. If it already exists, modify it
            Set oParam = oParamOwner.CreateParam(ParamName, oParamValue)
            Set oParam = oParamOwner.GetParam(ParamName)
            oParam.Value = oParamValue
            On Error GoTo 0
         End If
