Problem with saving as JPEG
Hello everyone,
today i discovered a little problem. When i tried to save a part to JPEG file, it apeared that it has purple gradient in the picture even though i have my background set to pure white color. I have also discovered that it only appear when i set my resolution to anything higher that 100 DPI, everything higher what 100 DPI will include the gradient colors in the picture.
Thanks in advance.
try adding following option into config.pro
graphics   win32_gdi
What version and build of Creo?
I did a 600dpi jpeg with white background in Creo4 M080 and it came out fine.
When was the last time you rebooted your workstation?
llibovič1-VisitorAuthor
Im using Creo 3.0 version M040. Im working on a laptop. i dont understand why is this happening. I have checked all the settings i have nothing set to purple, at least i think.
StephenW
Are you using some sort of render? The purple looks like the top of a "room wall" since it cuts off below the part and there is a "room" that has a purplish hue
