problem with starting Manufacturing
To whom it may concern,
Creo 2.0 Student Edition
Today I wanted to study manufacturing in order to program milling process.
I had clicked new > manufacturing (with checked nc assembly) > ok and nothing happened, it still remains at first screen.
Please provide me instruction how I can start milling processes!
Does student edition provide milling?
m.
I just installed Creo 2.0 M030 student edition and I'm having the same problem. Hopefully we get a response soon.
Michal,
look for floating options you may have to turn it on.
in all versions of pro/e manufacturing is a purchased option. you can get your designs made by saving an .stl or .step file. The least expensive 3d cam program that i have found is bob cad. you may be able to 3d print it.
Do you have a cnc mill available? I may be able to help you get gcode for your design.
Michal,
look into message window (bottom part of Creo window) after clicking new > manufacturing (with checked nc assembly) > ok. I guess you will see a message telling you that Student license does not contain Manufacturing licence.
Martin Hanak
