Problem with using distributed batch - symbol corrupted / becoming box
Hi everyone
I was trying to use distributed batch to export form .drw to .pdf.
I faced a problem that this symbol can't show up properly while using distributed batch feature
How it looks in .drw
When I export in manually, one by one
When I try to use distributed batch.
Everything is ok except this one. Glad anyone can help me.
Thanks in advance.
@AE_11094251 wrote:
Here are these 3 files.
Does I need to modify something?
INFO >>> files packed font.zip file are not modified.
I am sorry I do not have any idea how it is possible that you can see Mu character when you open prt0001.drw.1 drawing. It is possible that your Creo installation is modified in some unusual way.
Please place following note on the drawing. Do you see Mu character or square ?
PROE_MAT is model parameter. Its value is defined by model relation PROE_MAT=MATERIAL_PARAM("condition").
condition value is located in material definition saved in model.
1.] please upload test drawing (packed in zip file)
2.] what font do you use to display greek mu character ?
3.] what Creo version do you use ?
4.] what ttd file do you use do export PDF ?
Here is it, I attach .drw .prt .frm and .ttd as an example.
I use Creo7 version.
I don't know about the font. It was set a long time ago by senior worker. May you check it, refer in the file?
Thank you
Thank you
I opened your prt0001.drw and I can see your "picture no.3".
  • when I display text properties of problematic cell I can see that text is displayed using font named font
  • font named font does not contain definition of Mu letter ... therefore the square is displayed
  • when I set different font I can see Mu letter ... replay uploaded font_assignment.mp4 video
Emeritus
Hello @AE_11094251,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
