Problems with using combined state in drawing
Subject: Problems with using combined state in drawing
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
However, when you create a new layer and combined state and try to create a new view in the drawing, the views that have already been created change like the combined state created last.
I would like to know a setting that allows views that have already been created to maintain their combined state. Regarding this in 2d config it is currently set to draw_layer_overrides_model --> no, ignore_model_layer_status --> yes .
Translated with Google Translator by Hedy Jin on Jul 6th, 2022
Subject: drawing에서 combined state 사용에 문제점
그런데 새로운 layer와 combined state를 만들고 도면에서 새로운 view를 만드려고 하면 이미 만들어진 view들이 가장 나중에 만든 combined state처럼 변해 있습니다.
이미 만들어진 view들이 각각 설정된 combined state를 계속 유지할 수 있는 설정을 알고 싶습니다. 이와 관련하여 2d config에서 draw_layer_overrides_model --> no, ignore_model_layer_status --> yes 로 현재 설정되어 있습니다.
