Dec 28, 2012 5:32 PM UTC
Project sketch on exploded views
I have several projected sketches on an assembly andafter exploding the view,the projectsdon't move along with the parts. Apparently, wrap doesnt work on assemblies. Is there another way doing this besides project sketch?
Jan 1, 2013 8:39 PM UTC
The safe way to do that is to create the projected curvesin theindividual part files so the curves will always follow the parts in the explodes. If you have a situation where the curve spans across two parts, create a PubGeom that uses the same geometry in each part to keep continuity.
