Ddgschaefer21-Topaz II16 years agoOctober 1, 2010QuestionProjected sketch protrusion0 replies549 viewsTranslate AllYou need to use the offset tool instead, no projection required. Select the surface -> Edit -> Offset -> Select the 'expand' option(upper left of the image below) -> Options Tab -> Sketched Region Doug SchaeferSurfacing
