3-Newcomer
June 30, 2021
.prt file cannot be retrieved
I am using Creo Parametric - Release 4.0 (connected) 4.0 M030
I try to open certain .prt files from a customer and it gives message that it " cannot be retrieved.
I try to open an assembly and some ot the .prt files are not visible. the .prt files in the folder that cannot be retrieved.
I talk to the customer and they do not have this problem.
Here are the errors that I faced
" filename" cannot be retrieved.
StephenW
Its possible the files were made in a newer release of Creo, say Creo 5, 6, 7, 8.
You can open the .prt file with a text editor and just below  the header of the file, it will tell you what release and datecode it was saved in.
if you are exchanging data with a customer, then install the same Creo version.
3-Newcomer
July 1, 2021
The Creo version is the same.     4.0
Besides the version issue, are all of the customer files in a single folder or do you have your search path set to look in the proper folders for all of the component files.
3-Newcomer
July 1, 2021
all the .prt files are in the same folder.
certain  files do not load in the assembly.
if I try to load the .prt files that do not open in the assembly individually that is when and i get the "cannot be retrieved".
the funny thing is if I use third party translator they will load.
so that is my work around for now.
StephenW
I would say you probably need to send the files to PTC. If they are non-proprietary, you could try attaching one to this post and let someone on the forum try. Seems as if there is some sort of corruption.
