Nov 28, 2017 5:36 AM UTC
PTC_CONSTRAINT_SET
How to work with an assembly using PTC_CONSTRAINT_SET in relation and parameters.
HimanshuAnswer
Nov 28, 2017 8:29 AM UTC
Thanks for assisatnce :). I will try from my side.
Nov 28, 2017 6:44 AM UTC
I prepared test models in Creo Parametric 2.0 M070. See attachment PTC_CONSTRAINT_SET.zip.
In both cases you can set assembly parameter POSITION to 1 or 2 and regenerate to see the effect.
podsestava1.asm ... relations are defined on component level
podsestava2.asm ... relations are defined on asssembly level
Himanshu1-VisitorAuthor
Nov 28, 2017 8:22 AM UTC
Can record and provide me the video how to do it ?
Nov 28, 2017 8:25 AM UTC
I am sorry I do not have enough free time. Please open assembly and investigate parameters and relations. It is not complicated action.
