PTC Learning Connector Error
Hello everyone,
when i click on this icon bmancini_0-1646305871372.png to open "PTC Learning Connector" i get this error:
I have made several attempts but without success.
Can you tell me how to solve it?
Thank you
P.S. I am using creo 8.0.0.0
VladimirNAnswer
Read this article - "Unable to connect to LearningConnector starting from Creo Parametric 7.0.0.0": https://www.ptc.com/en/support/article/cs346017
VladimirN24-Ruby IVAnswer
bmancini15-MoonstoneAuthor
Thanks for your reply, the link in the program still can't make it work.
The only solution is to use the website directly.
It seems that I have answered my problem:
I set:
windows_browser_type chromium_browser
And
js_error_policy suppress_continue
Learning Connector does not support IE browser, so you need to change your creo browser to chromium one. to do this you have to change this in the configuration
  • Use config option windows_browser_type chromium_browser to enable Chromium in Creo
About the script error pop, when browsing a page containing JavaScript errors in an embedded browser, a popup is thrown, you can either close the pop-up or suppress it in config so that it will not appear again.
  • Setting "js_error_policy" to "suppress_continue" in config.pro allowed to not get the error
