PTC Learning Connector not working
I am using Creo Parametric - Release 3.0 (connected) 3.0 M090
Need help with PTC Learning Connector. PTC Learning Connector is Unavailable. I'm told we've been able to use this in the past, and none of us can open it now.
Here are the errors that I faced
LearningConnector is unavailable
    Dale_Rosema
    Emeritus
    @DS_9172866
    Thanks for posting to the Community!  I wanted to let you know that we are looking into this and will advise.
    @Dale_Rosema,
    @Jaime-Lee will be updating the announcement shortly, but there was a last minute change of plans and the transition will now occur Friday April 2nd between 2 and 6 am.
    Best,
    Leigh
    Seeing this exact issue this morning in Creo Parametric 6.0.3- is there any explanation or route to find a solution?
    StephenW
    It seems to be working for me this morning. https://learningconnector.ptc.com/
    I was able to view a tutorial.
    Started working shortly afterwards, so likely to have been a temporary outage or issue with our local network.
