Sep 29, 2026 2:21 PM UTC
PVZ Export Cannot find recipe
I'm using Creo Parametric 11.0.4.0. When I do File > Save As > Save a Copy and pick Creo View (*.pvz), the export fails and the message bar says "Creo View recipe file(proepview.pvr) can not be found." Here's what I've tried so far.
In the Options dialog I left the three recipe fields blank and I saved the profile to confirm they really were empty.
I looked in the config.pro and config.sup in Common Files and didn't see anything about recipes or Creo View. I also couldn't find intf_pv_recipe_dir or intf_out_pvs_recipe_file in the Configuration Editor, even though older posts mention them. When I searched my install, I found proepview.pvr in Common Files\applications\cvadapters\prodview\recipe, and export_pvs.rcp in Common Files\text\prodview. An older post here said they should be in the same folder, so I copied proepview.pvr into text\prodview. I also pointed export_profiles_creoview at that folder, restarted Creo, and tried again, but I still get the same error.
Does anyone know where Creo 11 expects to find proepview.pvr, or whether there's a setting or install step I've missed? Any help would be really appreciated.
Mahesh_Sharma
22-Sapphire I
Sep 30, 2026 3:01 PM UTC
Hi ​@AR_10119808
You may refer article at https://www.ptc.com/en/support/article/CS36497 regarding the same.
KenFarley
Sep 30, 2026 10:45 AM UTC
If you believe your problem might be solved by setting the two two config options mentioned,
intf_pv_recipe_dir
You won’t see those in the Configuration Editor because they are hidden options. To set them you have to edit your config.pro file with a text editor and add the two parameters yourself.
Hopefully that’s all you need to do.
Mahesh_Sharma
22-Sapphire I
Hi ​@AR_10119808
KenFarley
Sep 30, 2026 5:03 PM UTC
I’d definitely go with the support article. Hopefully you can read it. Answer from the article text is
Creo Parametric 11.0.0.0 and later: Starting Creo Parametric 11.0.0.0, The prodview folder is located at <Creo Install Loadpoint>\Common Files\applications\cvadapters\prodview
  • Set the following environment variable in the *.psf file
    • ENV=PVIEW_PROEPVIEW_HOME=%PRO_DIRECTORY%\applications\cvadapters\prodview
