Apr 14, 2017 9:01 AM UTC
Quantity in BOM table
Hi guys,
we are working with Creo3.0 without Windchill and we are trying to generate some kind of "structural" BOM table to use in our assemblies.
This BOM table will contain all parts of the assembly in the structure as the assembly is been assembled. So the table will look a bit as this:
  • ASSY-0001 (1x)
    • ASSY-0100 (2x)
      • PART-1000 (1x) -> (total=2x1 + 1x1 = 3x)
      • PART-1001 (1x) -> (total=2x)
      • PART-1023 (1x) -> (total=2x)
    • ASSY-0200 (1x)
      • PART-1000 (1x) -> (total=3x)
      • PART-2000 (1x)
      • PART-2010 (1x)
    • ASSY-0300 (1x)
      • WELD-ASSY-3000 (1x)
        • PART-3001 (1x)
        • PART-3002 (1x)
      • PART-3010 (1x)
      • PART-3011 (1x)
So far this isn't a problem, I just can sort my table on "rpt_level" and it will result in the correct structure.
In this table I also can get the quantities of all parts, without any problem by using the parameter "rpt_qty". This will result in the quantity of all parts in that "level" (sub assembly)
But now I'd also like to have the total quantity of each part in the BOM table. So this means that if some parts are in multiple sub-assemblies, the BOM-table will show the quantity of all parts in the main assembly. Does anyone know how to achieve this?
Below you can find a screenshot of the BOM table I have at the moment:
If it will help I can save the table-file here as well.
Thanks for your help guys!
18-Opal
Apr 19, 2017 6:11 PM UTC
Hi Geert,
You can get some further information on repeat region relations via the following Suggested Technique:
Suggested Technique for Using Report Relations to Control Repeat Region Parameters
Amit
Apr 20, 2017 6:04 AM UTC
Thanks for your answer Amit, but unfortunately we don't have acces anymore to the PTC portal, because we aren't under maintenance...
Do you know if this can be found as a PDF-file or something?
Geert
18-Opal
Apr 20, 2017 7:39 PM UTC
Hey,
I don't think you need maintenance to access the document, just a valid username and password.
See if you can create an account here and access the following document:
CS32734 - How to use repeat region relations to control Repeat Region Parameters in Creo Parametric
Amit
Apr 20, 2017 12:52 PM UTC
I think Creo repeat region functionality does not allow you to "compute" information for your Total QTY column.
Maybe you can save table as CSV file and "compute" information for your Total QTY column in Excel and then put it manually back into Creo table.
MH
Apr 21, 2017 4:14 AM UTC
Hey guys,
thanks for your answers, but it seems that it won't work in Creo it selves.
At the moment I've created 2 lists (one with the structure and one with the total quantity) and I've created one list in Excel with both Creo lists.
@Amit:thanks for your help, but if there is a chance to create a pdf-file of the article, it will help me in the future...
Cheers!
Jun 30, 2022 4:37 PM UTC
Hallo gpeetersem
Could you tell me, please, how I can get the Member of assembly  to the BOM? Like in your BOM. What is the report symbol? Attributes are No Dup/Level and Recursive?
Thank you in advance
Vaclav
