Question about part relations
  • February 10, 2010
  • 9 replies
  • 3977 views
I have a relation "d1=d0" between 2 features. If I change d1 from 0.1 to -0.1 and regenerate the dependent feature stays the same: i.e. it stays at 0.1. If I click on the feature >Edit, the dimension I changed to -0.1 shows up as 0.1, but if I go into the feature with Edit Definition it still shows as -0.1. I think this must be behind the problem as the relation is at the part level, between two features. How can I stop this from happening?
I've just dug up an old email from the PTC/User exploder list... Try $d1 = d0
Thanks, I'll try that. What does the "$" mean in this case?
From the Pro/ENGINEER Fundamentals Help Topics, the "$" character signifies an "absolute" value rather than a "relative" value. It forces the true signed value in the relation. Regards-
