Radius callout with an extra jog point, must use note callout, but need BASIC
- 4 replies
- 2302 views
- Translate All
I read that I cannot add a jog point to the leader of a radius, diameter, or chamfer callout. This is problematic, but I discovered a possible workaround™ in this forum... You reference the d### symbol in a leader note. The problem I have now is that the dimension does not show as BASIC. Is there a workaround for this workaround to make this function properly, or perhaps an option I missed?
The attached image has an example... this note references the dimension which is set to basic, but it does not display as basic.
