read file with some dots in to file name
  • November 4, 2016
  • 6 replies
  • 2924 views
Goodmorning PTC,
I would to ask you if it is possible to read file name with some dots with creo parametric 3.0.
thank you so much for your usual cooperation.
best regards
Creo filename must not contain "." character.
MH
First to all,
thank you for your prompty reply, but I have the problem with my customer that requires a matriculation with file name contains a dot.
I'm  trying to solve this problem also with another tool, compatible with creo parametric.
Do you know any tools useful for my scope?
thank you
Sorry, I forgotten to explain an important issue.I can export the file also in step format.
Thank you
