Ref Dim mapkey *(uses a temp view named 'w')
- 0 replies
- 665 views
- Translate All
The WF4 mapkey here works but was a bear to make consistent.... It
doesn't work with an active part in an assembly...
mapkey rd @MAPKEY_LABELInsert reference dimesnion;\
mapkey(continued) ~ Command `ProCmdViewOrient` ;~ Activate `orient`
`NmViewCheckBtn`1 ;\
mapkey(continued) ~ Select `orient` `namedviewPH.NameVw_List`1 `W`;\
mapkey(continued) ~ Activate `orient` `namedviewPH.NameVw_PB_Delete`;\
mapkey(continued) ~ Activate `orient` `OkPB`;~ Command
`ProCmdViewOrient` ;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `w`;\
mapkey(continued) ~ Update `orient` `namedviewPH.NameVw_IP` `w`;\
mapkey(continued) ~ Activate `orient` `namedviewPH.NameVw_PB_Save`;~
Activate `orient` `OkPB`;\
mapkey(continued) ~ Command `ProCmdViewAnnotOrient` ;~ Open
`Odui_Dlg_00` `t1.ViewChooser`;\
mapkey(continued) ~ Close `Odui_Dlg_00` `t1.ViewChooser`;\
mapkey(continued) ~ Select `Odui_Dlg_00` `t1.ViewChooser`1 `W`;\
mapkey(continued) ~ Activate `Odui_Dlg_00` `stdbtn_1`;~ Command
`ProCmdInsMenuMgr3dRefDim`;
Eric Slotty
- <">mailto:->
414-362-2552
Eric Slotty
- <">mailto:->
414-362-2552
