Oct 17, 2013 8:47 PM UTC
ref pattern type not allowed
Gurus,
I thought I did this in Wildfire 4 but now I'm not sure. I'm trying to use the "Pattern à Reference Pattern à Reference Type à Both" option and it won't work.
I assembled a bracket then patterned that bracket. Then I assembled a screw into a hole (patterned) in the bracket. Now I want to pattern the screw into all the bracket holes and all the brackets. Before, I thought, Pro/E was smart enough to recognize both patterns [the holes and the brackets] so I could pick both [as in "use both patterns"]. Now I am wondering if I am doing something wrong or this feature "pattern both" only works with grouped patterns.
Am I missing something here? You can see in the images that Pro/E recognizes both patterns depending on how I assemble the screw. I'm confused...please help.
See both images.
CREO 2.0 m040
Windchill 10.0 m030
Eric
Oct 17, 2013 8:52 PM UTC
Eric,
Assemble the bracket, then assemble the screw to the bracket and pattern the screw. Then put the bracket and the 4 screw pattern into a Group and Pattern the Group.
Chris
Oct 17, 2013 9:05 PM UTC
Thanks Chris. That is a usable option but I'd rather not clutter up my model tree with groups if I don't have to. Do you know how/when to use the "both" option? I don't understand why this is isn't working.
Eric
11-Garnet
Oct 18, 2013 4:18 PM UTC
Eric,
That's not how the reference pattern a patterned pattern works.
First, you create a pattern. Then you pattern that pattern. When you assemble a component to the lead feature of the lead pattern, then the reference pattern gives you the Group and Both options. It doesn't work if you pattern a component that contains a pattern itself.
David R. Martin II
Senior CAD Application Specialist
Amazon
