Oct 13, 2024 8:26 PM UTC
Reference does not get updated automatically
Hello
I have a reference pattern created from geometry present in another part in assembly. Referenced pattern does not get updated automatically, when I update my parent/main feature. What could be the main reason refernce pattern does not get updated automatically when refernce with external geometry.
I have also checked the update control is set to automatically
TIA
tbraxton
Oct 13, 2024 9:43 PM UTC
It would help if you listed what version of Creo you are using and describe or map the design intent that is relevant to the question at hand. Is the copy geometry feature an external copy geom or does it require the assembly to be in session to regenerate?
When using a copy geometry feature to drive a reference pattern in a derivative part, only the lead pattern instance in the parent model should be included in the copy geom passed to the derivative part. Do not include anything else in this copy geometry feature. Can you confirm that your copy geom only includes the pattern leader? If this is not the case start with this and use an external copy geom to pass the lead instance of the reference pattern.
11-Garnet
Aug 21, 2026 7:21 PM UTC
Yeah I’m also having similar troubles with assembly patterns, even only using the Axis type too.  I have a sneaky suspicion that it might be related to whether there are tangent contraints or constraints to multiple components/features.
I always find that I just have to delete the patterns and remake them every time...VERY annoying when analyzing different assembly positions (e.g. drag snapshots)!  We’re still on 8.0.3.  (I’m assuming this is not related to Copy Geometry feature?)
