Referring to subassembly parameters in drawing BOM
- 6 replies
- 3294 views
- Translate All
I have an assembly with some subassemblies. And each subassembly consists of some parts. All the parts in the assembly are inside the subassemblies so there are no parts on the top level of the assembly, only subassemblies.
All the subassemblies have a parameter assigned in them, "param_name".
I have a drawing of the top level assembly and would like to add a BOM table which shows only the parts and not subassemblies. And also I'd like to show the value of the "param_name" parameter of the subassembly where the part in question belongs to.
So in order to show only the parts in the BOM, I made the BOM table recursive and added a GATHERING_PART = YES parameter to each of the subassemblies. I then used the GATHERING_PART parameter to filter out the subassemblies from the BOM. So now I have only the lower level parts showing up in the BOM.
But I can't seem to figure out how I can read a parameter from a subassembly one level up in relation to the parts. Is there any way to do this?
I attached an image which I hope will help explain what I want to do.
