3-Newcomer
Regarding the direction of decomposition lines in an exploded view
When I create break lines for bolt heads and connecting holes, the cylindrical surface has no directional selection, so sometimes the break lines connect directly, while other times they connect with a bent line from the back, making it look messy. Has anyone encountered this problem, and how did you solve it?
kdirth
This has been an issue for a long time.  I usually try again changing the pick location on the bolt.  The only fool proof way to ensure the direction is to use axis to attach the offset lines.
Vote for this idea to let PTC know you feel an update is needed:
Smart Explode line - Assembly mode | Community
