Regeneration
I have been having an issue with regeneration of only certain assemblies.
For some reason whenever I activate a window of a large assembly that my coworker created in a folder it has long regeneration times (it doesn't do the same for him). But when I open an even larger assembly created in another folder, that has similar components, the regeneration time is instant. Does anyone know what could possibly be causing this?
Please specify which version of the program you are using.
Creo 8.0.2.0
you can do following test.
  • start Creo
  • open problematic assembly
  • create new empty directory on local disc ... eg. C:\Users\Public\Documents\mytest
  • backup problematic assembly into C:\Users\Public\Documents\mytest
  • exit Creo
  • start Creo
  • open problematic assembly from C:\Users\Public\Documents\mytest
  • regenerate ... how does regeneration behave?
Do you know why it seems like the simplified reps are having the issues with regeneration but not the master?
please do a local test and publish the results. Maybe some temporary data are created during regeneration and this is the root of "long time" regeneration problem when working with data saved on network drive.
It seems like it's actually the simplified reps that are my issue- the master rep regenerates quickly.
