Regeneration Failures
  • February 5, 2016
  • 2 replies
  • 1128 views
     I want to transfer my saved files and folders to a back up hard drive.  But when I do this, and then try to load any of the files again in Parametric it fails to load any of the parts and/or assemblies. It then requires me to go back to the original file and regenerate the whole file. How can I open files of an assembly or part saved to a different location then the original location and not have to regenerate from the old.
        -Someone new to PTC please be kind.
it looks like your problem is model dependent.
Please create simple part (a cube) and test its behaviour. You can upload test model using How to attach file when you Reply to a discussion. procedure.
MH
18-Opal
February 8, 2016
Kaina,
How are you backing up the models to the new folder?  Are you just copy/pasting them from Windows Explorer?
I would suggest open the assembly or drawing and then perform File > Backup and select the folder location to back up to.  Doing a File > Backup will force Creo to copy over all the necessary files for successful retrieval.
Amit
