Relation
- 8 replies
- 348 views
- Translate All
Can someone help me to create a relation in a bom to change a parameter to another number for cage_code? I have something at the bottom of the relation in the bom table that is obviously incorrect.
I have attached a simple drawing in creo 8. If you can perform the task and return to me then I will understand how it is done. Should only take a guru less than 5 minutes.
Wayne
