Aug 3, 2022 5:55 AM UTC
relation between xtop and parametric exe
I am using Creo Parametric - Release 5.0 (connected) Release 5.0 and Datecode5.0.6.0
Opening creo parametric 5.0.6.0, two exe are opening in task manager xtop.exe and parametric.exe, what is the relation between these two exe's??
when we open two creo parametric, How to relate which xtop.exe is for parametric exe. As there are 2 xtop and 2 parametric exe. present.
Aug 8, 2022 5:57 AM UTC
I have found the relation between the two exes:
parametric exe
⬇️     is parent of
command exe
⬇️   is parent of
xtop exe
tbraxton
Aug 6, 2022 5:36 PM UTC
Each xtop process is associated with Creo being launched and is specific to date code. You can find a unique xtop process in the install path for Creo.
i.e. C:\Program Files\PTC\Creo 7.0.7.0\Common Files\x86e_win64\obj
Here is task manager showing two xtop processes running when both Creo 4 and Creo 7 have been launched.
Mayuri_Patil10-MarbleAuthorAnswer
parametric exe
⬇️     is parent of
command exe
⬇️   is parent of
xtop exe
