2-Explorer
May 26, 2015 7:41 AM UTC
Relation in Repeat Region
I would like to know how one can use OR into repeat region relation.
My scenario is as below:
If PartName = "001" or Param1= "001_Updated"
/*Do something
end if
Regards
Ketan
2-Explorer
May 26, 2015 8:48 AM UTC
If you have OR you can do like this:
If PartName = "001"
/*Do something
end if
If Param1= "001_Updated"
/*Do something
end if
May 29, 2015 8:43 AM UTC
If CREO has no "OR", you can use a variable as a way around it.
i = 0;
if i=0
     if partname = "001"
          /*Do
          /*i=1
     end if
end if
if i=0
     if partname = "001_v2"
          /*Do
          /*i=1
     end if
end if
This way, in case you have both, it won't do the same action twice.
May 29, 2015 12:16 PM UTC
There is an ELSE function that may work.
I haven't tried this, so it may need to be tinkered with:
IF PartName = "001"
/*Do Something
ELSE
IF Param = "001_Updated"
/*Do Something
ENDIF
ENDIF
2-Explorer
May 29, 2015 12:20 PM UTC
I need to do same thing for PartName as 001 and 001_Updated both... Else condition will not work as repetition will happen. In addition to that, I do have scenarios of 002 and 002_Updated and so on as well....
Regards
Ketan
2-Explorer
May 29, 2015 12:52 PM UTC
Use the "|" to represent the OR function. "&" is for AND.
TomU
May 29, 2015 5:08 PM UTC
Creo relations, including repeat region relations, uses the ampersand (&) for AND and the pipe (|) for OR.
IF PartName == "001" | Param1 == "001_Updated"
    /* Do something
ENDIF
TomU
May 29, 2015 5:11 PM UTC
Sorry David.  Your post wasn't visible when I was replying.  Hopefully the forum bug isn't back.
