Relation in repeat regions
- 5 replies
- 2192 views
- Translate All
I have a message error in a repeat region with relation.
I have 2 assembly types:
- ASM 1
- ASM 2
In the ASM 1 I have the AC1_LEN_SE parameter, which is a tube length parameter
In the ASM2 I have the AC1_LEN_XX parameter, it is also a tube length parameter)
We need to know the total tube length by subassembly reference, whatever the assembly typology.
My repetition table is used in the drawings of asm1 and asm2.
I have the desired result, but I have the following message which I do not understand.
"There are errors regenerating repeat region relations."
Can you help me understand this message and how to resolve it?
Below you will find the table.
Greetings
