2-Explorer
May 1, 2015 11:38 AM UTC
Relations (Else If) in Repeat Region
I am able to set relations in repeat region as below:
if asm_mbr_name == "PRT0001"
CAD_SAP_PLM_IDX = "1000"
else
CAD_SAP_PLM_IDX = RPT_INDEX
endif
I would like to understand how to use else if into relation. My scenario is as below:
  • CAD_SAP_PLM_IDX = "1000" for "PRT0001"
  • CAD_SAP_PLM_IDX = "1001" for "PRT0002"
  • CAD_SAP_PLM_IDX = rpt.index for rest all parts
Thank you in advance.
Regards
Ketan
Dale_Rosema
May 1, 2015 2:13 PM UTC
Remember that for every "if" you need and an "endif" at the end.
I have a word doc that I can cut and paste as needed (a sample of that file):
IF asm_mbr_pn == "9594"
NEWQTY = "0.5"
ELSE
IF asm_mbr_pn == "9556"
NEWQTY = "0.5"
ELSE
IF asm_mbr_pn == "9151"
NEWQTY = "0.5"
ELSE
ENDIF
ENDIF
ENDIF
May 1, 2015 1:50 PM UTC
By stacking up all the ifs. Each if statement has to end with an endif.
else
if asm_mbr_name == "PRT0002"
else
if asm_mbr_name == "PRT0003"
CAD_SAP_PLM_IDX = "1002"
else
endif
endif
endif
Dale_Rosema
NEWQTY = "0.5"
ELSE
NEWQTY = "0.5"
ELSE
NEWQTY = "0.5"
ELSE
ENDIF
ENDIF
ENDIF
TomU
May 1, 2015 2:25 PM UTC
To summarize, there is no built in "ELSE IF" in Creo. You can get the same effect by using "ELSE", then another "IF", then another "ELSE" and so on, but deeply nested "IF" and "ELSE" statements can get tough to follow.
For repeat region relations I prefer to set the default value and then check for the other conditions. (The last one set "wins".)
IF ASM_MBR_NAME == "PRT0001"
ENDIF
IF ASM_MBR_NAME == "PRT0002"
ENDIF
2-Explorer
May 2, 2015 3:50 AM UTC
Thank you all for help.
