Relative Accuracy Problem in part model
For one of the components in an assembly is having an issue of relative accuracy.
All features of this component are not getting generated after removing further material from it. As estimation of relative accuracy is not proper.
One of the solution can be to adjust the 'min.' dimension to clear this relative accuracy.
If there can be any other solution (so that dimensions will not be altered), pls. share the details.
Regards
Prateek Agarwal.
