Remove all breaks in an axis line
I have a question in drawing environment,  about axis lines that already have a break because there is a dimension there:eix_1.jpg
some days after, the dimension is no longer necessary, so I delete it. How can I remove the break in the axis line?
I am using creo4. Thank you very much
StephenW
StephenWAnswer
While in the Annotate tab, select the Axis, then in the ribbon in the Delete area, there is REMOVE ALL BREAKS icon.
StephenW
StephenW23-Emerald IIIAnswer
