Jun 16, 2017 7:23 AM UTC
rename a part with its associated drg files
is there any way if my part n drg file both are open & if rename a part file den associated drg file will rename automatically???
2-Explorer
Jun 16, 2017 8:02 AM UTC
I think this is not possible.
Jun 16, 2017 8:18 AM UTC
I guess you don't use any PDM system. It's easy there.
I face the same problem when trying to rename more parts with their drawings.
The solution isn't nice but exists:
- check if the option rename_drawings_with_object is set to "both"
- open the top assembly and choose the command Save a Copy instead of Rename
- use e.g. Dummy.asm for copy of top assembly
- rename the parts you want. Make sure the option "copy drawings" is ticked.
- click OK, close objects, erase and open windows commander
- delete the original top assembly file and rename the dummy.asm to original name
- delete the dummy.drw if exists and close windows commander
I don't understand why there isn't same option "copy drawings" in rename window as it is in Save a Copy. But it is like it is...
Hope it will work
Jun 16, 2017 12:45 PM UTC
To my knowledge there is not a way to rename a part and drawing file together at the same time in Creo.  It can be done within Windchill though.
Would be a great product idea though!
Jun 16, 2017 2:38 PM UTC
t is possible but there a couple requirements.
The file name of the model and the file name of its drawing has to be EXACTLY the same.
This will not work.
123abc.prt
123abca.drw
This will work.
123abc.prt
123abc.drw
There is a config.pro option that should be set.
Default value = none
Values = none, both, part, assem
Jun 16, 2017 2:43 PM UTC
Good to know, thanks for the information!
