rename_drawings_with_object not working
Just updated to CREO 12.4.3.0 and now rename_drawings_with_object is not working.  When someone does “replace by new copy” in assembly mode, the drawing is not copied.  It worked fine in previous version.
3-Newcomer
Same problem here, very annoying, this needs fixing
Open a support ticket with your reseller or with PTC Support if you’re a direct customer. Reporting it here will not solve the problem.
Looks like this relates to PTC Article CS462346 and PTC implemented a fix in Creo Parametric 11.0.9.0, 12.4.4.0, and 13.4.1.0.
