Jul 25, 2022 3:56 PM UTC
repeat region filter limited to 80 characters
I have a filter condition which exceed the limit of 80 characters. (&asm.mbr.name==...)
The opposite condition doesn't result in a shorter formula.
I tried to use "or" ( | ) but didn't success.
&asm.mbr.name == *val1*, *val2*, *val3*,...
|asm.mbr.name == *val11*, *val12*, *val13*
Do you know a solution ?
Thanks.
Jul 31, 2022 9:38 AM UTC
discuss your problem with PTC Support.
KenFarley
Aug 8, 2022 10:52 AM UTC
You have not specified what version of Creo you are using, so perhaps the repeat relation functionality has changed since Creo 4.0.
Either way, maybe the following (extracted from a pertinent article, CS150475) may be informative:
How to write a repeat region relation that uses a wildcard in Creo Parametric
Applies To
  • Pro/ENGINEER and Creo Elements/Pro Wildfire 2.0 to Wildfire 5.0
  • Creo Parametric 1.0 to 4.0
Description
  • How to write a repeat region relation that uses a wildcard
  • It always gets the wrong result when add a relation in repeat region
Cause
Resolution
Aug 18, 2022 8:34 PM UTC
Give us a better description of what you are doing with the relation?
Relations have always been limited to 80 characters.
Aug 19, 2022 7:49 AM UTC
I think OP needs something like
&asm.mbr.name == *val1*, *val2*, *val3*, *val4*, *val5*, *val6*, *val7*, *val8*, *val9*, *vala*, *valb*, *valc*, *vald*, *vale*, *valf*, *valg*, *valh*
Length of this line is 152 characters. It exceeds 80 characters limit.
