Feb 9, 2010 1:50 PM UTC
Repeat Region in Table > Report Symbol?
Hello everybody, I would like to add 2 new columns in a table: Material and Treatment This parameters are filled in the drawings of the parts (thanks to the .frm files) as: "&nom_mat" and "&traitment_th" Do you think that I can call this parameters with a Repeat Region? And if yes, how I have to proceed? (I just want to know which Report Symbol I have to use) I work on WF2. Thanks! Sylvain
Feb 9, 2010 1:53 PM UTC
here is a picture of my problem: HELP! Please
Feb 9, 2010 3:30 PM UTC
Try asm.mbr.USER_DEFINED, then type the name of the part parameter. I know that works in WF3 and up. It has been a while since I've done it so I hope I git the names right. Good luck.
Feb 11, 2010 12:37 PM UTC
Thanks for your answer, but I'm sorry, it doesn't works. Are you sure that it works on WF3? Maybe WF2 don't accept this kind of process. If I succeed, it will be very interesting for the efficiency of my company... Do you have another solution? Does anyone else have a solution? Please
