Nov 24, 2015 2:15 PM UTC
repeat region summation parameter in assembly relations
I am totally stuck on this.
In a repeat region I have used the summation command to get the total weight, but only being able to use this value in the current drawing is only half of what I need it to do.
I need to have the total weight of an assembly to be in the assembly relations.
I have made a mapkey but what I'm looking for is something fully automated.
Does anyone know how to do this?
here is another thread but I think the customization group might have some good insight.
Repeat region summation.
Maybe using a vb.net program to do this to all drawings all at once?
Thank you for your time.
Nov 24, 2015 3:07 PM UTC
assembly weight is saved in system PRO_MP_MASS parameter.
MH
SYNDAKIT15-MoonstoneAuthor
Nov 24, 2015 3:24 PM UTC
Hi Martin good to hear from you.
yeah I really like that solution but I hit a road block because of how it uses quantity; here are some examples.
on the part level i change the source to be parameter, then I add weight=pro_mp_mass or maybe I did weight=pro_mp_alt_mass.... but anyway...
if there is an item that has a quantity of (7) and weights .5 Lbs, the weight for that item 7@.5lbs=3.5  and where I work they want to calculate the weight by doing this.... floor((weight*qty)+.5).   and so i tried putting that at the part level something like this--->  weight=floor(pro_mp_mass+.5)
that would give me weight=1 at the part level, then the assembly level would be a total of 7 Lbs. when what my company wants is  4 Lbs
  so that brings me to the quantity issue. if there were some way to pull quantity i could do the weight at the assembly level, but then I would just be back to manually entering weights for newly assembled parts.
grrr... I'm so close to having this fully automated
Nov 24, 2015 3:35 PM UTC
Use weight=pro_mp_mass + 0.5 / 7
