6-Contributor
Repeat Regions / Filters
I'm trying to exclude parts from the BOM. I was instructed to open Repeat Regions, then select Filters, then click on the BOM and 2 options would appear, Remove: By Rule or Buy Item. But it will not even let me click on the BOM. Not sure why its not functioning properly.
kdirth
kdirthAnswer
Check out this post:
Solved: Table Filtering - PTC Community
Chris3
Are you sure that your table is a repeat region?
It should work like this:
https://youtu.be/xAge8cmyAj8?t=465
DANIEL_MD6-ContributorAuthor
6-Contributor
When I select By Item it gives me this....:you may not perform this action due to symbol asm.mbr.cparam
kdirth
kdirth21-Topaz IAnswer
