Replace by unrelated component
Starting with Wildfire 5 there was an enhancement made so that if a part is duplicated it could be replaced using the unrelated component and evaluation rules. The rules look for the same entity IDs and then auto-pair them.
Does anyone know of a way to make this happen with assemblies? For instance if I have a part that I now realize needs to be an assembly. I assemble the part into an assembly and how I want to use the evaluation rules to auto-pair the IDs for replacement.
If no one knows of a way to do this I will make it into an idea.
