Sep 20, 2022 12:33 PM UTC
Replace Component By Family Table - Family Tree Show Table by default
Does anyone know if there is a config.pro param that can be set to Show Table by default when Replacing a Component by Family Table in an asm?
Sep 20, 2022 2:33 PM UTC
Here's a mapkey that you can start from. You'll need to replace the bold text with the parameter name that you want to show in the table.
!!!REPLACE SELECTED BY FAMILY TABLE
mapkey RFT @MAPKEY_LABELREPLACE SELECTED BY FAMILY TABLE;\
mapkey(continued) ~ Command `ProCmdReplComp@PopupMenuTree` ;\
mapkey(continued) ~ Activate `gen_repl_dlg` `PB_NewComp`;\
mapkey(continued) ~ Activate `mdlbrowser` `SwitchCol`;\
mapkey(continued) ~ Update `column` `InpName` `desc`;\
mapkey(continued) ~ Activate `column` `AddBtn`;\
mapkey(continued) ~ Activate `column` `OKBtn`;
StephenW
Sep 20, 2022 1:34 PM UTC
I don't think so.
You can probably automate most of the picks with a mapkey that would get you right to that screen that you want it to be.
